320 Gb HDD from Toshiba
iPod Classic (new one) will accept Toshiba 320 Gb HDD?
What about this: http://www.amazon.com/Apple-iPod-classic...
좋은 질문 입니까?
좋은 질문 입니까?
If you are thinking about using the Toshiba MK3233GSG in your ipod, then the answer is no. It will not work because it has SATA interface. The 320GB is a dual-platter one, that means that the interface wont fit and it has different mechanics as well . The HDD for the 160GB iPod is 5mm thick and the 320 GB is 8mm. Hope this makes sense. Good Luck
해당 답변은 도움이 되었습니까?
There is a 250GB drive out there with an ZIF - IDE Interface. As far as i remember they tested it in a 5.5G iPod Video and it worked.
해당 답변은 도움이 되었습니까?
Thanks you :)
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,358
댓글 5개
need more information on the 320GB. What is the drive number? What is the interface....your ipod is a 6th gen classic?
oldturkey03 의
Thank you. What about this:http://www.amazon.com/Apple-iPod-classic...
Ted 의
If your question is if this one will accept the above drive, then the answer is no. Same problem.
oldturkey03 의
Thank you verry much.
Ted 의
You are welcome, good Luck
oldturkey03 의
