주요 콘텐츠로 건너뛰기
The Dell Dimension E510/E520 is a desktop computer released in 2004.
7 질문 전체 보기
Restore Dell Dimension E521
How do you restore or repair a dead Dell Dimension E521?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
What is wrong withit?
댓글 달기
답변 1개
가장 유용한 답변
Hi @tear_fall12
What really happened?
cannot power on or boot up well?
IIRC this Dell series, notorious for bad bloated capacitors in the mainboard.
http://iamnutsandsoami.blogspot.com/2012...
Inspect the board and the power supply unit on that.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
It's *usually* the power supply. Any ATX unit will suffice on these, but you need to watch the cable length by the hard drives. The motherboards are usually solid.
I appreciate your help. I will have to find some times to try it out.
Thank you very much
댓글 달기
귀하의 답변을 추가하세요
Maikao 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 188
