주요 콘텐츠로 건너뛰기
Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
111 질문 전체 보기
Water Stain Under Screen
Spilled water on my Macbook Pro this morning. Have fully powered down. Allowing to dry in sunlight. Diagnosis and best course of action?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
The discoloration you notice is because the liquid/moisture damaged the backlight layer of your screen.
No actual electronic components seem to have suffered damage.
Your MacBook will probably keep running normally (depends if some liquid-moisture actually made it to the LCD, corrosion could build up slowly over time and damage the LCD, but it seems like everything dried up)
The only way to fix this is by replacing the full display assembly..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
SPat 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 77
