Fans run at 5800rpm with no CPU usage
The fans on my MacBook Pro 15" Retina Display Mid 2012 (macOS Catalina) often run at max 5800rpm without any high CPU usage. The CPU Core temperature are high at 90°C but I don’t know what is causing that…
Sometimes my CPU does peak at around 120% when watching youtube on google chrome, which also causes my fans to run at max. People suggest to use Safari instead, which I would like to avoid if possible since I have everything synched on chrome (Work, School, Personal). Looks like Safari only fixes the youtube/high CPU % problem?
Here is a screenshot of my activity and Mac Fan Control
I can’t seem to find the source or a solution for this problem. Not sure if it’s a general fan problem since it’s older macbook.
Notes I saw on other threads:
- no, I have not spilled anything on my macbook
- my room temperature isn’t high either
- I downloaded the chrome extension h264ify to avoid the youtube VP8/VP9 problem
Update (04/21/2020)
@danj here is the screenshot showing my current TG Pro and activity window. I just have a youtube video and twitter open in the background (to get the same effect)
좋은 질문 입니까?
댓글 9개
Restart your system and press the D key to enter into the onboard diagnostics. Let us know if you get any error messages.
Dan 의
@danj I do get the following error:
Error: 0x8000000000000003, Cannot Load 'EFI/Drivers/TestSupport.efi'
Status: 0x00000003
Pam 의
Rats! You hit the firmware bug Apple intro'ed.
Lets clean off as much as you can of auto loading apps and the fan control app you are using I don't trust MacsFanControl I've seen some wacky issues with it.
Instead lets use this one which offers diagnostics TG Pro you will need to fork out the $10 to get the diagnostics.
Dan 의
@danj thanks! Hope "hitting the firmware bug" means there is a solution to this? I purchased the TG Pro version and will attach a screenshot as a reply (not sure if I can add pictures here in the comments). As for auto loading apps I have only have an app called magnet.
Pam 의
The bug has been reported to Apple a few times ;-{ I fear its on the very bottom of their bug list. You know the saying 'the squeaky wheel gets the grease' Post a bug report as well.
Let's pull magnet out as we need to reduce the variables.
Dan 의
댓글 4개 더보기
