주요 콘텐츠로 건너뛰기
Model A1199 / 2, 4, or 8 GB capacity
85 질문 전체 보기
nano is on but wheel function not working
My nano is fully charged and on but the wheel is not wroking. I press on menu or play and nothing happens. I tried to reset it by holding down the menu and select buttun but it did npot work
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
가장 유용한 답변
First try restoring it on iTunes. but if that doesn't work, it's very probably it is bad hardware. Try replacing the clickwheel (and headphone jack/case assembly) but if that doesn't do it, it's a bad motherboard.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
screen unlock system rebooting and taking off the code.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Would you mind putting this into a complete sentence?
댓글 달기
Repair on my screenlock chromatic code 2generation code.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Would you mind putting this into a complete sentence? Instead of starting a new answer please just comment under your first one.
댓글 달기
I had my 2nd gen nano, which I locked up on me. I used to workout with it and think it was moisture that caused it to seize. I put it aside in my closet and didn't touch it for a year. I fired it up just recently and it works as good as new. If this happens to any of you I recommend trying to demoisturize it by buying some silica and putting it in a ziploc bag.
Good luck
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
fran 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 6,067
