주요 콘텐츠로 건너뛰기
The Maytag model LDE8604ACE is a gas dryer produced by Maytag.
16 질문 전체 보기
Why is my dryer dead
Hello,
Last night when I went to put my clothes in the dryer my light on the inside wasn't on. I closed the door and push the buttons to see if it would work and nothing happened. I unplugged the dryer and plugged it back in and nothing. I checked the breaker and it wasn't tripped. So I turned the breaker off for a few seconds then back on, still nothing. Can you please help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Hi,
Check if the thermal fuse has operated. (part #10 - motor drive parts diagram)
If the fuse has blown it will have to be replaced.
Be aware that there is always a reason why a fuse may blow e.g. if the hi-limit thermostat is faulty and allows the dryer to get too hot then the thermal fuse will operate to prevent a fire from occurring. I’m not suggesting that there is a problem with the thermostat, just that the thermal fuse is the backstop in case anything goes wrong.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
sweetbear18488 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 252
