TV turns on sometimes
I have a Phillips LED TV, and it would sometimes turn on. Like, you need to hit the button several times before it turns on. But now, it just won’t turn on. I pulled the boards, and all the electrolytic caps hold a charge. I’m not sure if I should replace the caps, or if something else is potentially wrong. If you think that I should replace the caps, which ones are most likely the cause? Should I do all of them? There is no bulging or leakage. There are about 30 of them.
좋은 질문 입니까?
Hi @diodes123 ,
What is the model number of the TV?
Which "button" are you referring to, the TV's Power button (if it has one) or the TV remote control unit's Power button or both?
jayeff 의
@jayeff The model number is 46PFL3608/F7. There is no power button on the TV, even though it's from 2013. I even tried holding the power button down on the remote. Also tried different power outlets in different rooms. When I try to power it on, I hear a click sound, then nothing.
Erik Slowik 의
