주요 콘텐츠로 건너뛰기
Successor to the PowerShot G7 X, the Mark II was released as Canon's flagship model in 2016.
19 질문 전체 보기
camera says "memory card locked"
My memory card has the switch in correct position as i can view pictures on a computer and on the camera screen, however it says Memory card locked the whole time and wont let me take pictures because of this? please help - Thank you. Lollu
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Hi! Have you solved this problem?
on the sd card there is a lock switch if it is down flick it up and it should work because i have had this problem before
댓글 달기
답변 2개
선택된 답변
If the lock switch is in the open position, it usually means the flash is in a permanent read-only state. When the lifetime of the flash is close to being used up, this is a safety feature to preserve the data as reading doesn't do much harm to the card, if any at all. They allow this as a means to move the data, at most. Be glad it acted this way, since a lot of cheap cards which do not self lock tend to fail and take out whatever is on the card. Having to buy a card on short notice is far from ideal sure but I want a chance to save what's on it.
If you want to try and see if it can be fixed, backup the card to a PC, and then format it in the camera and see. In most cases, the flash is end of life and it will fail as it's a firmware level lock.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thank you very much!
댓글 달기
Hi,
There is manual lock option on Memory card used in Camera; please see the picture and try to solve the issue.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
lollu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 21
30일 전: 130
전체 시간: 3,349
