A range of desktops aimed at the mainstream consumer market, spec-wise situated between the Inspiron and XPS lines.
56 질문 전체 보기
Laptop not turning on, but the quickplay button lights on.
My Dell Studio 14 does not turn on. when I pressed the power button, the quickplay button lights on for a few seconds and nothing happens after that. there are no sounds at all. is it related to motherboard failure??
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
2개의 답변
선택된 해법
You did not specify the model number of your unit so I've provided a link to the 1435 service manual. I hope that is correct.
http://support.dell.com/support/edocs/sy...
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
Try to turn on your laptop without the battery on (only with the plug adaptor).
If this doesn't work, it is probably a hardware issue (although more inspection is needed before reaching this conclusion).
해당 답변은 도움이 되었습니까?
점수 0
댓글:
I've tried. i even tried the upside-down trick but it didn't work.
thank you.
의 답변
What is the make and model of your laptop?
의 답변
mine is dell studio 14.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Ran John 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,129
