주요 콘텐츠로 건너뛰기
조이콘 컨트롤러와 약간 더 작은 스크린이 통합된 보다 합리적인 가격의 순수 핸드헬드 버전의 Nintendo Switch의 게임 콘솔입니다. 2019년 9월 20일 출시.
175 질문 전체 보기
Broken wire-to-board battery connector on Nintendo Switch Lite
While replacing the left thumbstick, I disconnected the battery cable from the connector (circled in photo). Unfortunately, I broke one of the contacts on the connector. I’ve searched for the connector, thinking I could desolder the broken one and replace it, but I can’t find a match. An alternative, I suppose, is to hard-wire in place of the connector, but I’m not wild about that option.
Any suggestions?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Hi, I'm wondering if you ever attempted to solder this, and if so how did it go?? Literally have the exact same problem ... and I also did it while replacing an analog stick.
did you ever figure this out
댓글 달기
답변 4개
선택된 답변
Contact TronicsFix on youtube, charming guy with a lot of Switch parts. I’m pretty sure he could sell you a battery connector or even replace your broken connector.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Great suggestion! I'll contact him - thanks!
댓글 달기
가장 유용한 답변
there’s a few solutions,
  1. buy a broken motherboard and salvage the connector
  2. solder it directly, pretty jank but it should work. be careful when soldering it and check for shorts afterwards.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks @xtopnotch. I haven't given up yet on finding a replacement connector, and your suggestion for getting one from a junk board is a good one. Turns out, we have a replacement Switch Lite we can use while we ponder this a bit, to see if a parts unit comes available (or we find a suitable connector we can swap out). I appreciate your quick reply.
댓글 달기
I found the piece on aliexpress if you cannot find a motherboard for it. i had the exact same problem sadly. As i was repairing the joystick too. https://m.aliexpress.com/item/4001264431...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Did this ever get fixed?!? I just did this. I have a 250+hour island on animal crossing, I cannot lose it!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brett Fontaine 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 6
7일 전: 17
30일 전: 83
전체 시간: 5,083
