주요 콘텐츠로 건너뛰기
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
406 질문 전체 보기
Extracting the disc drive key on a laptop
Hey, so I have an Xbox 360 Zephyr with a ruined disc drive pretty much. It wasn’t reading games well, so I tried changing the laser and that didn’t help. Not it won’t even close properly and etc… So I was thinking to change the drive itself, but as far as I know, you have to extract the key from the old one and transfer it into the new one. So, I wanted to know, if there’s any way to do it on a laptop? Like with adapters or something?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Why not just keep the drive controller board and put it in a new drive? No hacking required.
There are adapters available, not sure if they still make them. I don’t think hackable adapters will be cheap, or if you are good at it, buy some kind of USB-to-SATA engineering adapter and run it with 360 drive flashing utilities. There should be open sourced ones available, but they expect you to be expert hacker level to use it.
If you need to ask how, chances are you can’t do it. So just buy a new drive of the same model and swap the board.
해당 답변은 도움이 되었습니까?
점수 2
2 댓글:
The problem is, it's a BenQ VAD6038 drive and it requires soldering to swap the board which I'm not familiar with that.
Soldering is going to be a hundred times easier than hacking, also those dev board adapters may require soldering as well, so you need to solder either way.
댓글 달기
귀하의 답변을 추가하세요
Tomasz Videos 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 640
