이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 3개
If one of these answers fixed your problem please hit the "accept" in list that has "History Edit Flag Accept Comment" located to the upper right of your question so we can remove it form the unanswered list. Thanks so much.
The G5 1.8Ghz Uses a 64-Bit Microprocessor, that is capable of 1.8 Billion Operations Per Second, and since it it 64-Bit, it doubles the Bitwidth of the G4, and G3(32-Bit) and if i am corect, than 1,800,000,000 X 64(Bits) = 115,200,000,000 Bits Per Second
댓글 3개
mayer 의
Chris Green 의
and that is for the 1.8Ghz model, the 2Ghz is faster
Chris Green 의
