MacBook Pro 15" Core Duo Model A1150
Ok so here is my problem...
I replaced the dvd drive the top case with keyboard and outside top case. And now my mbp a1150 1.83 GHz wont start or make any noise at all just nothing. the magsafe light stays green always even with the battery on and the battery has a charge. I've check everything the ribbon cables for the track pad all are connected. the display is connected all screws are in place. I tried to short the pins on the logic board and nothing happens. I really need help ASAP this is my only laptop and is the one I use for my business. Any suggestions, tests are welcome.
좋은 질문 입니까?
댓글 6개
I tested with a MM and it has voltage 3.3 volts
Shogun 의
What has a voltage of 3.3 volts?
rj713 의
the pwr pins
Shogun 의
I also checked the memory it well connected
Shogun 의
Do you have the 85w power adapter?
rj713 의
댓글 1개 더보기
