주요 콘텐츠로 건너뛰기
MacBook 제품군은 2006년 5월에 처음 소개되었으며 Apple의 가정용 노트북 iBook을 대체하였습니다.
3787 질문 전체 보기
My Mackbook Core 2 Duo 2007 Black can-not charge the Battery.
This Macbook is working all fine just that it can't charge the battery.
- The battery is good as I charge it externally with the External Charger I bought - meaning I can use my macbook for like 2 hours or so at one charge.
- Following the ifixit and some other forums I have now replaced the faulty part which is Meg Safe Dc - in but still it doesn't Charge.
I appreciate you guys reading this forum , please Suggest me something if you have in Mind.
Thank you, Joy.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Check the battery connection for corrosion and completeness. Also check its connection to the board. If all that is good and you have a meter see if you are getting charging voltage to the pins.
MacBook Core 2 Duo Battery Connector Replacement
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
joykubavatz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 363
