4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
3267 질문 전체 보기
iPhone wont turn on after screen replaced without itunes
I changed the back and screen of my iphone, was very careful with everything and it went smoothly. But my phone doesnt turn on. I plugged it in to charge and it come on, but it says it has to be plugged in to itunes. when I plug it into my computer to connect to itunes it wont turn on. Any help??
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
You may have a problem with either your battery connection not being on fully or dirty, or it may be the dock connector. Either way the best solution is to open the phone back up again, clean all the connections as advised in the repair guide and then carefully reassemble. You may like to try a wall charger for 1 hour first. It may be that your battery is very very low and this is why it isn't recognised in itunes.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
raquel 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,022
