Suddenly super long boot time and sluggish cursor
I changed the LCD on my 2011 MBA. Everything seemed fine. When I put the webcam cable on, the connector fell off so I replaced it with an I/O board from a 2009 MBA. After that, the MacBook air is super slow to boot and when I finally get to finder the cursor is sluggish and everything is lagging. So I put back the original I/O board. Same super slow response. I have tried to reset SMC, NVRAM, even if I take out the SSD and boot from a USB install it takes ages to boot. I formated the SSD and installed a fresh OS X 10.13.6. It behaves super sluggish no matter what I do. Has anyone experience this?
##update
Here is a picture of the webcam cable connector fallen off
- I did a hardware test. No problems found.
좋은 질문입니까?
댓글 2개
Please post some pictures of the original parts so we can see the damage 기존 질문에 이미지 추가하기
Did you try running the onboard diagnostics to see if you get any error messages. Restart the system and press the D key, did you any errors?
DanJ 의
On startup the progressbar goes to about 80% very fast then stays there for 15 minutes. When it finally finishes the machine super sluggish. In verbose mode I can not see any errors, it finishes verbose then opens to Apple logo and there is stays for so long until it finally is finished and then super sluggish like I wrote before.
asle 의
