주요 콘텐츠로 건너뛰기
9월 20일에 출시된 가장 크고 비싼 2019년 Apple 스마트폰으로 6.5" OLED 디스플레이를, 트리플-렌즈 카메라 시스템및 크게 향상된 배터리 수명이 특징입니다. iPhone XS Max의 후속 제품입니다.
124 질문 전체 보기
I had glue on my fingers and accidentally glued my charger into the ch
I had glue in my fingers and accidentally glued my charger into the charging port of my iPhone pro max. How do I get it out?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Two options and there is the possibility that option 1 won't work so you will have to use option two. Option one: open the phone up and disconnect the battery. Then take a qtip soaked with acetone until it breaks down the glue then pull it out. Then make sure it's nice clean of glue and then clean it out with alcohol. Blow it out with air and make sure it's dry and hook up the battery and see if it works.
Option two: change the charging port. It would be the best solution and you don't take a chance of possibly shorting it out and frying the motherboard. The charging port is about 5 dollars or less and it's not that hard to do it. What the repair videos on YouTube or you can pay someone to do it for around 50 to 100 dollars includes parts. I hope this helps
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Belinda Burroughs 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 33
전체 시간: 558
