주요 콘텐츠로 건너뛰기
Apple Inc.에서 (예전 Apple Computer, Inc.) 제작한 iMac 개인용 컴퓨터 라인의 첫 번째 모델은 1998년에서 2003년 사이에 제작되었습니다.
92 질문 전체 보기
Why won't my old 1998 blue iMac turn on?
I have an old blue imac. It will not turn on. I tried the button on the keyboard and on the monitor. I check the plug and it was plug in the computer and outlet. I tried another cord and no luck. Could it have something to do with the battery inside?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
If your date and time started showing incorrectly or your printer dropped off line before you had the start problem, then more than likely your 3.6 volt 1/2 AA battery died and needs replacement. You can also try resetting the PRAM and NVRAM, here's how:
To reset the PRAM you simply:
Shut down your Mac.
Locate and hold simultaneously the Command (Apple), Option, P, and R keys.
Turn on your Mac and hold the key combination before the gray screen appears.
Only release the keys after the computer restarts and you hear the startup sound for a second time.
If this doesn’t fix your issue you can take the next step which resets the NVRAM.
Restart your Mac.
Locate and hold down the Command (Apple), Option, O, and F keys.
Your Mac will boot into command line prompt.
Type the following, hitting return after each line:
reset-nvram
set-defaults
reset-all
UPDATE
Here's how to change it: http://www.satcure.co.uk/accs/imac.htm
Here's the battery or Radio Shack sells it for $20 : http://www.ebay.com/itm/Tekcell-1-2AA-3-...
해당 답변은 도움이 되었습니까?
점수 10
댓글 7개:
When my imac was working it was showing the date as 1956 so it probably is the battery. Is it easy to change? Where do I get the battery?
much better price!
Yes I replaced the battery and it works!! Thank you everyone for your help!!
Glad I could help solve your problem.
댓글 2개 더보기
댓글 달기
귀하의 답변을 추가하세요
Mary 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 26
전체 시간: 12,444
