주요 콘텐츠로 건너뛰기
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
212 질문 전체 보기
Model MVWX655DW1 Doesn't fully agitate.
My washer is no longer agitating fully and is not getting my clothes clean. It will go through the rinse and spin cycles properly, though it seems to fill the tub up almost completely…which I don't remember it always doing.
Makes a louder than usual clicking noise when on the “Wash" setting, but tub barely goes back and forth.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 6개
is your washer a belt drive or an actuator & stator?
These models have a belt and an actuator. The actuator has failed. Mine was doing exactly the same thing. I replaced the actuator and calibrated the washer. Its been working great for over a year now...
Hey did u ever find out what the proble was I have this same issue
Did u ever find out what the problem was I have this same issue?
Transmission went out
댓글 1개 더보기
댓글 달기
답변 3개
가장 유용한 답변
Washplate
If the washing machine will not agitate correctly the washplate might be damaged and stripped off the drive shaft. The agitator can be removed to check out the washplate connection point.
https://www.repairclinic.com/PartDetail/...
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thank you. I appreciate you help. It's working fine now.
댓글 달기
Hi @nyckid69
The washplate sits on the hub and should move with it.
Here's the tech sheet for the washer.
Run the diagnostics as described in the sheet and check what error codes you get. The sheet describes what to check for each given error code.
You should be able to find out about the lid lock problem as well
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
After many hours of research. And an actual fix of my own, I found out that it's the actuator that fails. They have an internal plastic pin that rotates the cam on the actuator to engage with the gearbox. ( shifts gears) These tend to break off. The washer will work normally throughout it's cycles but the agitation will be very weak. Remove the actuator and if the little arm is just dangling replace it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 10개:
I think that’s my problem too. Where did you purchase a new actuator?
@brandiaoaks ,
Search online for "(insert MODEL number of washer) parts" to find suppliers.
The better ones have parts diagram showing the location of the part e.g. partselect.com, searspartsdirect.com, repairclinic.com, appliancepartspros.com just to name a few
Order it from Amazon, Ebay or your local appliance store. Very simple to replace.
I replaced the actuator. It sounds like it’s doing more to agitate the wash, but it doesn’t move the basin the way it’s supposed to. Any suggestions?
Actuator arm is not dangling and still does not engage. Also my lid lock doesn't lock either.
댓글 5개 더보기
댓글 달기
귀하의 답변을 추가하세요
Laundry Mama 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 18
7일 전: 77
30일 전: 289
전체 시간: 9,435
