주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
Replaced Battery, Still not Turning On?
I have an iphone 7, it finally gave up last week, wouldn’t turn on anymore. I tried DFU and the phone died in the middle of the process.
Installed a new battery today, after about an hour’s charge, I plugged it into iTunes, where the DFU process worked as expected. I downloaded a whole software update but now the phone won’t turn on at all, won’t respond to hard reset or DFU. What’s going on?
Do I need to wait for the battery to fully charge maybe?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
This could be a software issue. If that’s the case, you should probably ask Apple for help…
However, if you are 100% sure that the battery isn’t the problem, there might be some issue with the logicboard. That’s possible to replace, yes but hard. And you would probably lose touch ID features as each individual home button is paired to the logicboard to the phone. And with the fact that this isn’t a physical button and just a sensor, you won’t even get the ability to click your home button unless you go through Apple which will re-pair a new one for around 379$…
These issues are always hard to fix, as I usually tell most people to restore the whole phone, but it seems like that isn’t an option here… I don’t like to say it, but I’m afraid that Apple is the only way here if no genius here might have a great solution.
But if a wipe and a restore is possible, I highly recommend you to hook it up to iTunes and restore the phone.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Andrew Truglia 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 42
