주요 콘텐츠로 건너뛰기
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
156 질문 전체 보기
GBA SP AGS-001 Won't power on even with good battery
I have a GBA SP AGS-001 that will not power on. It charges fine with a good battery, but will not power on regardless. When attempting to power on, the green power light flashes for a moment, and then nothing. Any ideas would be appreciated, Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
where did you get said, "good battery"?
댓글 달기
답변 1개
Hi Liam!
With good battery, you mean it’s tested? Or used at a different SP?
Alright.. First I advise you to check the ribbon cable if it’s seated as it should.
Next, is to check the motherboard if something is damaged or felt off.
Nintendo Game Boy Advance SP Motherboard Replacement
Check the cap, do some measures and check the battery pins.
My guess: Motherboard related OR ribbon cable not seated properly (for the DS Lite series, this issue happened if the ribbon cable was loose or not seated as it should. It looks like it’s all good and seated as it should, but it wasn’t..)
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
i had the same problem , checked everything i could but still making the same thing evem cleaning with isopropanol
댓글 달기
귀하의 답변을 추가하세요
Liam 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 275
