주요 콘텐츠로 건너뛰기
Apple AirPods are wireless headphones released December 2016.
My right Airpod wont work at all.
My right Airpod won’t work at all. It won’t register that it's in the case and that its in my ear. The bluetooth is fine and the case still works because my left Airpod is normal and working. Its only the right Airpod.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
Can you add a little more info? Were they ever dropped in liquid? How long have you had them for?
@hootonberg I've had them since October last year. I never dropped them on the ground or accidentally dropped them in water. I take good care of them and the right one just stopped working a couple days ago.
well they're still under warranty so see what apple can do.
댓글 달기
답변 2개
가장 유용한 답변
the internals such as the motherboard may be messed up, and since they are impossible to repair, id recommend buying a replacement airpod from ebay
https://www.ebay.com/itm/164164025653?ch...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Check the charge status on your iPhone or iPad to make sure that each AirPod is charging . Put both AirPods in your ears. Play audio to test both AirPods. If an AirPod still isn't working, reset your AirPods or contact Apple Support.
Regards,
Will
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Loba 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 176
