주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy A40은 2019년 4월에 출시되었습니다.
Samsung A40 stopped charging yesterday following him dropping it.
Hi, my brothers Samsung A40 stopped charging yesterday following him dropping it, resulting in the phone being bent. The phone is now completely dead and he has a replacement in the mail. However, he doesn’t want to lose all of his images and contacts. Any suggestions?
Thanks.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 3개
가장 유용한 답변
do as in the movie. or press the phone on the back in the fingerprint area. hold and connect the charger
https://youtu.be/SS_nAF4tMFk
이 답변이 도움이 되었나요?
점수 6
댓글 3개:
OMG, this worked ! Thank you Jacek Sopel.
'or press the phone on the back in the fingerprint area'
Genius, worked
It really worked my phone started charging
댓글 달기
You have problem with:
# Charging dock (Charging port or FPC connector) - needs replacement.
# Main flex cable - needs replacement.
# FPC connector on the motherboard - needs repair from technician.
Samsung Galaxy A40 - does not charge - how to diagnose the problem
이 답변이 도움이 되었나요?
점수 1
댓글 달기
He can open it up and check the connections for the battery and the charging port, a connection could have been knocked loose. He could also connect a battery to the phone and extract the data or take the battery out and charge it with a battery charger you can pick up on Amazon for 20 dollars
이미지
do you have to return the phone? If so will you get in trouble if you open the phone? You can have a repair shop take the back cover off and charge the battery and get the data.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Chloe Stephens 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 4,627
