주요 콘텐츠로 건너뛰기
Upgradability of iMac 21.5 inch
I am planning to buy an iMac 21.5-inch Retina 4K but I would like to know how much upgradability there. I know that the RAM is upgradable up to 64GB. I am buying one with a 1TB Fusion Drive, but can I change this to an SSD after purchasing? Since Apple charges a lot for extra storage and RAM. Can I also upgrade the processor? It comes with a Core i5 but if it is possible I would like to upgrade to an i7 at minimum.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
선택된 해법
YES!! you can pretty much upgrade everything except the display
해당 답변은 도움이 되었습니까?
점수 0
댓글:
@ranger1509 - Please expand your answer! What are the drive options and limits as well as which CPU's are workable.
@ranger1509 - That is not correct! Intel CPU's have micro code loaded in the systems ROM. This microcode is unique per the chips series as an example here Coffee Lake: Intel Core i3 (8100), Core i5 (8500), or Core i7 (8700).
The other variable is the TDP can't be more than 65 W. So as an example a i9-9900K (Coffee Lake) is 95 W which won't work properly in this system as the power supply and cooling would not be able to support it.
What are the logic board I/O's for storage devices?
의견 추가하세요
귀하의 답변을 추가하십시오
Abel Benoie 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 177
