주요 콘텐츠로 건너뛰기
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
221 질문 전체 보기
Units will only charge through firewire not USB
Hi
I have several ipod 4th gens that will only charge through fire-wire, and not through USB. They sync through usb, but do not charge. It is like they turned into 3g classics!
Any known solutions?
thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Try a different USB port, they do not all supply the same power. Try using a high end USB cable.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
the only other thing I would like to add to this is that you could have iPods with batteries that are at the end of their lifespan. Usually the higher voltage and amperage supplied by the Firewire connection has the tendency of charging those batteries, USB does not. Of course this only holds true if your computers USB port and cables are working properly....
댓글 달기
귀하의 답변을 추가하세요
matt prior 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,740
