Can I replace the Bluetooth module from 4.0 to 5.0?
Is it possible change my MacBook Pro’s Bluetooth module from 4.0 to 5.0?
Because my AirPods connection is poor when I’m in a crowd.
If it possible could you recommend the module?
좋은 질문 입니까?
좋은 질문 입니까?
Sadly, there is no newer AirPort boards for your system (Bluetooth 4.0). Your only option is to use an external USB adapter, just make sure macOS is supported.
You may have a simple problem as the Bluetooth antenna line could be damaged and all you’ll need to do to regain the signal strength is to replace it. Its still a bit of a job as you need to remove the lid to following this guide MacBook Pro 13" Retina Display Mid 2014 Display Assembly Replacement as you need to get the black clutch cover off as the antennas are underneath it MacBook Pro 13" Right Hinge, Antenna/iSight cable
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 173
