주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
So I found a 2015 MacBook
So I found a 2015 i7 16gb ram 1.5 gb vram, 512gb ssd for 660 but there is a major issue, the connector for the keyboard is torn off
would it be possible to just get some solder infused in flux and put it on and solder the connector directly without replacing it. Thanks
I realize that this isn’t the right way to fix it, I’m just wondering if it would be a usable option since I can’t find a place to buy the connector
Update (06/23/2020)
So replacing the trackpad will also make the keyboard work again?
asking because the keyboard and trackpad don’t work
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
In this series the trackpad is more than just a trackpad! It's also the junction point for the keyboard. So it's not surprising the trackpads failure is also causing the keyboard not to work.
Have you tried using an external USB keyboard and mouse to make sure the system is even working? I would start there.
If that didn't fix things then you have to replace the MacBook Pro 13" Retina (Early 2015) Trackpad Cable which connects to the trackpad carrying both the keyboard and trackpad signals to the logic board.
Yes it works perfect with external keyboard and mouse
댓글 달기
답변 2개
선택된 답변
The connector that is missing is part of the trackpad
I would just replace it as I’m sure you really can’t solder the ribbon down without creating a short or causing other issues.
MacBook Pro 13" Retina (Early 2015) Trackpad and here’s the guide MacBook Pro 13" Retina Display Early 2015 트랙패드 교체
MacBook Pro 13" Retina (Early 2015) Trackpad 이미지
상품
$54.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
If you just “Found” this device, the right thing to do is find it’s owner
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
No no, I meant I found it on eBay that’s why I had the “for 660” included
댓글 달기
귀하의 답변을 추가하세요
David bellows 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 65
