주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
591 질문 전체 보기
New battery won't hold a charge
Otherwise seems to run normally, but dies when unplugged from charger. Problem persists after battery replacement. I’ve reset SMC and tested with multiple chargers. Charger light is green and doesn’t switch to amber. Battery icon on menu bar shows charging symbol but remains at 0%. Coconut battery says current charge is 0 and full charge capacity is 0.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
After sitting plugged in for a day, it’s now working fine! It seems like if you’ve replaced a totally dead battery, the machine might need a long time charging to recalibrate the new one, even if you’ve reset the SMC.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This sounds like you have a damaged charging logic on the logic board. This often happens with knockoff chargers!
Don't Replace Your MacBook Charger With a Cheap Knockoff
OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
Lacking safety features, cheap MacBook chargers create big sparks
FAKE Magsafe MacBook Chargers on eBay - Watch before buying a Mac Charger
Please get a REAL Apple unit and get rid of the knockoffs! [https://www.apple.com/shop/product/MC461...?|Apple 60W MagSafe Power Adapter (for MacBook and 13-inch MacBook Pro)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
thardee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 10
전체 시간: 882
