주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
265 질문 전체 보기
How do I fix colored lines down my screen caused by pressure?
My laptop was open and I had been using it. I went to push the screen back a little and placed my hand around the side of the screen (so my thumb was on the screen and the rest of my hand was on the back (in picture). Suddenly a bunch of lines popped up tracing to where my thumb was and have not gone away in weeks. The glass itself is not broken so I think the issue is underneath. Is this fixable? How expensive would it be to fix?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Same thing happened to my school computer I don't think you can fix it yourself they are taking mine to get fixed and its gonna be 550 dollars
댓글 달기
답변 2개
선택된 답변
Sorry to tell you the back glass (LCD panel) is cracked!
I often see this happen when something like a pen or pencil was resting on the keyboard and the lid was closed on it.
You’ll need a new display assembly 13” Retina MacBook Pro Display Assembly, Apple P/N 661-7014 and here’s the guide you’ll need to follow MacBook Pro 13" Retina Display Late 2012 Display Assembly Replacement
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
Thank you so much!
My brother has an old Macbook Pro from early 2011 (the one that still had the disk drive) but it is very slow . Can I take his LCD screen and put it in my Retina Macbook Pro
@sabrinabruno3 - Sadly, you can't use your brothers system for parts. There is too many differences for it to work.
Just like cars which look alike from the outside one uses gasoline and the other uses diesel! All you'll do is damage the engine if you put in the wrong fuel into the wrong car!
댓글 달기
can i know how much would it cost to repair this screen so basically what happened is a usb was between the lid and the keypad and i closed without noticing and boom i have got this cracked screen with lines on it
does it require a full screen replacement
what would the cost for repair at an apple store
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Sabrina Bruno 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 6
7일 전: 57
30일 전: 346
전체 시간: 14,048
