주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
A collection of guides and support to help with washer repair.
2504 질문 전체 보기
Samsung Flex Washer Front Load Door Locked
My Samsung Flex Washer Door is locked. Wash cycle completed and i drained the water from the washer but the door will still not unlock. How can I unlock to get my laundry out.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Hi @skbgirl ,
What is the model number of the washer?
@jayeff @jayeff WV55M9600AV/A5 is the model number
의견 추가하세요
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
Nintendo Switch 키트 쇼핑하기
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
답변 1개
선택된 해법
Hi @skbgirl ,
Have you tried disconnecting the power from the washer for 5 minutes and then reconnecting and checking if the door can be opened? Just a thought.
Don’t know your model but have found the service manual which as far as how to manually open the door is not helpful.
You could try the manual mode of smart install test #1 as described and then step though to the end of the tests without pause to see if this releases the lock. Suggest that you don’t try automatic test or any other test in manual check mode as it says tests are to be done without clothing in the washer.
Sorry I can’t be of more help with this one. Washers are getting too smart nowadays.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Sherri 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 36
