trying to install os 9.0
have cd won't boot holding c key
좋은 질문 입니까?
Try booting the machine up in system 10 then insert the OS 9 disk and install it. It should go right in.
해당 답변은 도움이 되었습니까?
not sure if this is what you meant, but you won't be able to install OS 9 on this kind of machine using generic OS 9 install discs. instead the install discs for this particular machine will let you install "Classic mode" on the machine, allowing you to run OS 9 apps (but not boot in OS 9)
bac- That's what I'm trying to do, install classic mode.
This unit will run OS9 in classic mode but will not boot into OS9. OS9 will run in classic mode only in OS10.0 through 10.4. It will not run classic in 10.5. Ralph
해당 답변은 도움이 되었습니까?
The iBook G4 will not boot up in OS 9, nor will any other Mac introduced after Jan 2003.
see this Apple support document, "Some Computers Only Start Up in Mac OS X"
as rj713 already mentioned, you can only run OS 9 in "classic mode" on this machine
해당 답변은 도움이 되었습니까?
That article also states that OS9 is a file on the install disk that comes with the computer---ie the additional software. Ralph
The last machine to be able to boot in 9 was the G4 MDD 1.25. Once system 10.5 is installed system 9 will not work in emulation mode. None of the G4 iBooks will boot in system 9.
해당 답변은 도움이 되었습니까?
sorry rj, didn't mean to step on your toes. You changed what you said while I was typing my answer.
No problem--I needed to edit to include the info on 10.5. Ralph
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,594
