주요 콘텐츠로 건너뛰기
MacBook Air 11"의 2015년 3월 업데이트는 5 세대 Intel Core i5 및 i7 프로세서를 장착하고 배터리 성능이 약간 향상되었습니다.
140 질문 전체 보기
MacBook Air 11" - Interchangeable logic boards?
Hi to all, I’m a bit new to the MacBook home repair game and hoping to find some good advice here.
I have a MacBook Air 11” A1465 early 2015 model that needs a new logic board. Like most people i’m on a budget and have found a nicely priced MBA 11” Mid-2012 A1465 logic board. Will the 2015 model take the 2012 logic board? If so would it result in any issues with ports etc due to it being a few years behind the newer model.
Appreciate any help people, thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Sorry, it won’t work ;-{
Apple altered things enough in Mid 2013 to 2017 models so that the 2012 logic board won’t fit or work properly. Your SSD which is PCIe 2.0 x4 won’t work in the mSATA slot in the 2012 logic board so you’ll also need a new SSD making the cost higher.
Frankly, the performance difference will be quite noticeable as well!
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Cheers, guess I’ll just have to bite the bullet and buy a 2015 logic board. Thanks for the answer
@adubz - Don't forget to score and accept the answer - Thanks!
댓글 달기
In theory, it should. Just make sure the 2 boards have the exact same specs.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Andrew 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 7
전체 시간: 160
