주요 콘텐츠로 건너뛰기
모델 A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 또는 3.8 GHz Core i5 또는 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K Display. 시스템이 매우 유사하므로 이전 iMac Intel 27" Retina 5K Display (Late 2014 & 2015) 안내서를 참고하십시오.
293 질문 전체 보기
I can’t split my fusion drive
I am trying to split the fusion drive in my 1tb iMac so I can replace the HDD with a 2TB Samsung ssd and use that as my boot drive instead of the blade ssd. I followed the guide that was suggested as well as others and none have worked.
Errors:
https://imgur.com/a/VApe20z
here is my previous post here about it;
Replacing the Fusion HDD with a SATA SSD?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Let’s see if we can figure things out. First lets get a snapshot of Disk Utility. Make sure you alter the view to show All Devices in the top left corner of the menu bar. On the left column you should see your physical drives. Click on the top one and expand the tabs. Take a snapshot at each layer container and then the volume. Do the second drive in the same way. Make sure you capture the full window each time posting them here for us to see 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
Okay I have added the photos to the post
@chemicalsam - Looks like you have two partitions on the HDD! One called 'MacintoshHD' and a second called 'MacintoshHD - Data' It looks like 'MacintoshHD' is not part of the Fusion Drive set and is your OS drive, which is odd! That could explain why your system is so slow! As you are not leveraging the SSD at all for the OS! I think thats why you can't break it as its not part of the Fusion Drive.
At this point I think the smarter direction is just making a full TimeMachine backup of your MacintoshHD-Data drive partition. And just restore after you've switched things out.
After looking up the two partitions it seems to be a completely normal drive behaviour on Catalina. https://discussions.apple.com/thread/250...
@chemicalsam - APFS is a moving target ;-{
댓글 달기
귀하의 답변을 추가하세요
Heddle 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 468
