주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
The ASUS ZenPad 3S 10 is a 9.7-inch tablet in the ZenPad line released by ASUS in October 2015. Model: P027.
18 질문 전체 보기
Power button may be stuck, the tablet just continues to reboot
I dropped it and now the power button is slightly off (seems to be stuck in to the case on the bottom of it) and so it keeps coming on with ASUS and Medaitek screens but then immediately reboots. Any ideas of how to fix it?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
You could open easily removing the 2 screws, remove the sd card and follow youtube instructions. When it’s open unplug the buttons connector. If the tablet stop rebooting is problem of the buttons if not I don’t know. The buttons could be easily bought on ebay. If the tablet stays switched off you could switch on with a small screwdriver touching in two pins at the back where you unplugged the buttons flex cable. You could also try how reacts when you charge and so on to discard battery, charging port…
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
C. M. 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 31
