주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
Apple 워치 시리즈 2 는 2016년 9월 7일에 발표되었고 2016년 9월 16일에 출시되었습니다.
106 질문 전체 보기
Force touch sensor adhesive not sticking very well
Hello,
I have a AW series 2, replaced the cracked screen and the force touch sensor since it ripped when replacing screen.
The force touch sensor comes with “adhesive” but doesn’t appear to be very strong. After putting everything back together within a few hours the screen already starts separating. I tried putting pressure on the watch with a heated pad but I’m wondering if anyone else has run into this issue.
Would it be advisable to use 3M tape on the top and bottom of the force touch sensor or would that cause too much clearance. ?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
답변 1개
Just so you’re aware, because you replaced the force touch sensor, it won’t pair with a new phone. Like the home button with TouchID, that sensor is tied to that specific board. As far as the screen adhering, adding more adhesive could cause a clearance issue. I would try replacing it again, but use some heat and some clamps to heat it up after you install the display then clamp it down and let it sit until it cools completely.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
That's what I ended up doing is just using some heat to keep the LCD seated.
I was unaware that the force touch is tied to the watch. The force touch was replaced and the watch works fine as it was already paired.
Do you have any reference as to the force touch being tied to the watch? I have never heard anything about that. Is it only for certain generations?
@Tyler Perroux it'll work just fine with the phone it has already paired with. But if you unpair it, it won't ever pair to a device again. Hold on while I try to find some references. The only way I found out about it was because of the facebook group I'm in for cellphone repair shops.
의견 추가하세요
귀하의 답변을 추가하십시오
Tyler Perroux 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 38
