주요 콘텐츠로 건너뛰기
Part of Google's third generation of Pixel phones, the 3a is a budget-minded option with the same camera as Google's flagships. Available in Clearly White, Just Black, or Purple-ish. Released May 2019.
60 질문 전체 보기
Screen flashing and touch problems after replacement
After replacing the screen on a Pixel 3a, the screen will flash (like a single bright strobe) when waking the phone up or sometimes when opening an app. Also, some screen taps are missed and entering text has to be done slowly to prevent missed letters.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 2개
It sounds like a bad connection. Disconnect the battery and unhook the screen and make sure that there are no bent pins. I would then clean the connectors with a qtip and alcohol and a soft brush. Put it back together and hook up the battery last
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hello, Brandon! Did you manage to find a solution?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brandon Ankeny 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 708
