주요 콘텐츠로 건너뛰기
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 질문 전체 보기
Is the replacement really "difficult"?
On the repair guide (iPad Mini 2 LTE Front Panel Replacement), is the repair really “difficult”? It seems like it should be pretty easy. What makes it so hard (take a screen off, put a new one on)?
If it helps, I would buy this part (iPad mini 1/2 Screen Digitizer)
iPad mini 1/2 Screen Digitizer 이미지
상품
$34.99
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
I wouldn’t say its very difficult personally, but it can be if you haven’t done it before. Make sure that you are opening it up from the correct side and don’t tear the cable as you open it up. Use plenty of heat and playing cards or picks, and make sure there aren’t any bends or breaks in the casing before laying down the new screen or it won’t fit quite right.
Hope that helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Do I need to transfer the camera or home button over to the new screen? Or unscrew the LCD?
You will need to unscrew the LCD to access the cables underneath. The camera will stay in place, but you will have to transfer the old home button over to the new screen.
댓글 달기
What makes iPads in general a pain to repair is the glue and the home button, especially models with TouchID. Thankfully these ones don’t use it so if you tear the button, it’s not the end of the world. Use plenty of heat and be patient. Avoid touching the LCD with your bare hands. It’s harmless if you do touch it, it’s just a bit of a pain to clean if you do. Use actenone and a Q-tip to clean off any adhesive residue from the frame once you get the old screen off. It’ll make sure the new screen stays put! You can also “Frankenstein” the device to test the new digitizer before you glue the new screen down.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ComputerHeroes 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 77
