Stuck on bootloader screen
stuck on bootloader screen. when I try to re-boot it just keeps coming back to boot screen
좋은 질문 입니까?
좋은 질문 입니까?
Try a Hard Reset.
해당 답변은 도움이 되었습니까?
+ I like it when you talk like that. Ever thought of running for president?
Is the operating system stock Android that came with your phone?
If you installed a custom ROM, sometimes they can cause your phone to "boot loop" like that. Most of the time using a different kernel will solve the problem. That only applies if you're not using the stock operating system, though.
해당 답변은 도움이 되었습니까?
If you rooted the phone go into the root menu: With celll off hold down button volume tap power on while holding down. Go to recovery do a wipe cache then go to advance and do a wipe cache in your selected rooted. MOST of the time this will repair the problem.
해당 답변은 도움이 되었습니까?
step 1 turn off phone
step 2 count to three
step4 throw it as hard as u can at the ground
step5 pick up phone place gently in trash
step6 walk away.... lmao
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 4,366
