주요 콘텐츠로 건너뛰기
9월 20일에 출시된 가장 크고 비싼 2019년 Apple 스마트폰으로 6.5" OLED 디스플레이를, 트리플-렌즈 카메라 시스템및 크게 향상된 배터리 수명이 특징입니다. iPhone XS Max의 후속 제품입니다.
135 질문 전체 보기
No internet or Wizfi
I have a iPhone 11 Pro Max that was dropped and drove over by a golf cart. Had the screen replaced already and thought was good. Back is also still cracked. Cellular part still works but can not use the internet or WiFi. Any idea what I need to buy. Has no protection for repairs. So I thought I would myself. Please help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
You could start by changing the wifi antenna but my guess is the connection in between the split board is broken. I would take it to a repair shop that does microsoldering work and have it checked out. Also if the back is cracked and it gets wet water will poar in.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Im having a similar issue with an 11 Pro Max. During set up, Im not getting any wifi available. As well as this, when I am pressing the little 'i' in the right hand corner, it is not showing any IMEI information. I am aware that usually this is a baseband problem. However, I recently figured out that swapping the signal antenna brings back the baseband (in most case). Do you think that changing the charge port (where Im assuming the other signal antenna is) would also be worth swapping out, along with the wifi antenna?
Thanks in advance
댓글 달기
귀하의 답변을 추가하세요
Wallace Harper 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 168
