The side adjuster of the right earphone
The side adjuster of the right earphone is broken, it's the part that holds and supports the entire earphone without it I have to hold the headphones while listening to music.
좋은 질문 입니까?
좋은 질문 입니까?
Hey!
Taking a look into the manufacturer’s page on this product this part seems to be built from cheap plastics and not intended to be user-serviceable, in which case it is going to be rather hard to get the replacement part, also the screws used are not of a standard bit shape, that also makes the fix harder. If you have the bit perhaps opening and taking a closer look at the part and craftily repair it with some run of the mill epoxy resin, I would recommend against super glue as its solvent has a tendency to destroy plastics.
Cheers, Enzo
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 19
