주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2265 질문 전체 보기
iPhone 7 won't charge after DIY battery replacement
Hi,
Today I’ve replaced battery in a friend’s iPhone 7. The replacement went smoothly, no problems, and I’ve replaced many batteries prior to this one. However, after the replacement, iPhone refuses to charge. Even after connecting the battery, iPhone still doesn’t charge.
What I’ve tried:
  • Using multiple cables and power sources (all of them worked with my iPhone XR but none worked with this iPhone 7)
  • Connecting the old battery
  • Turning the iPhone on by plugging it to power outlet (this worked and the iPhone powered on. Tried multiple times)
  • Putting the iPhone into DFU mode (since this only works when connected to a computer. Worked fine.)
So, based on what I tried, I have no clue what’s going on.
The phone still gets to DFU, powers on by plugging it into outlet but it just refuses to charge. Any ideas what could’ve happened?
Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Was it charging with the old battery? If it was you have most likely nudged one of the tiny resistors while replacing the battery. You will need to take some measurements on the connector to confirm unless you can check with some decent magnification.
If it wasn’t charging the old battery it would most likely be a faulty charging IC. Either way it will need to be repaired by a reputable repairer unless you have microsoldering skills.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Petr Molek 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 57
