LCD power connector problem? And how to fix It
Hi,
my screen fell of, and it snaps a little bit power connector on Logic board, one of the pins is loose, and backlight on screen does not work (computer works fine when plugged to external monitor, also on built in screen after turning iMac It is possible to see Apple logo.
How can i fix It ? I want to solder pin back, but what voltage should i see on this pins ? Anyone has graph for that ?
Update (08/17/2020)
@danj Thanks Man,
I’ve soldered pin right to its place but, screen still does not have backlight .
I’ve check continuity on pins and they looks ok, two pins on left have same connection to the chip below is this correct ?
I want to make sure that Logic board is fine before ordering a new screen :)
좋은 질문 입니까?
@danj thans for the tip :)
does anyone have information about voltages i should see on this pins ?
Raf 의
Sorry I don't have the schematics for this series. I would just test continuity across the connector pin by pin.
Dan 의
