주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
745 질문 전체 보기
MacBook Pro 2009 won't turn on
Hi,
My macbook was overheating so much that I decided to re-apply thermal paste. I had to take the logic board out, but when I reassembled it it didn’t turn on. I thought it was power issue because when I connected the adapter, the battery indicators started flickering, so I bought a new battery.
Oh, BTW, my old battery was dead so I didn’t have it connected and it worked just fine before.
Today new battery finally came so I replaced it, it came 50% charged so i fully charged it (it took about an hour) and then tried to turn macbook on. It didn’t work. Then I tried to turn it on with charger connected and it still didn’t work. What should I do?
Thank you
Edit: I forgot to mention, this happened to me one time before, but I just waited for like 30 minutes and it turned on. Now it’s been dead for like a month.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
It sounds ridiculous, but try it out. Cover the exhaust vent with some linen careful with fire hazards (at your own risk) , switch on your Mac for couple of minutes it should heat up in few minutes like 30 and should be running again.
I had same issues with one of my laptop, It was repaired like this there are micro joints in CPU which fixes automatically like this . Try it out if you think it'll work.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
But I can't even turn my Mac on, I need different solution
댓글 달기
귀하의 답변을 추가하세요
Anže Kranjc 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 42
