메인 콘텐츠로 스킵하기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
3274 질문 전체 보기
Do I really need an antistatic strap/mat to work on an iPhone?
Ok, I have searched the questions here and read a few articles on it already. Most of the questions were dealing with Desktops and Laptops, not phones. I'm going to replace my home button on my Iphone and one of the "recommended" items listed was the Antistatic strap. Is this really needed to work on phones?
Thank you!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
3개의 답변
선택된 해법
not until the first time you see a spark shooting from your fingers and zapping some of the NAND flash menory or other SMD parts....:-) At least follow these simple steps when you work on ANY electronics....http://www.computerhope.com/esd.htm it's called good practice.
해당 답변은 도움이 되었습니까?
점수 4
의견 추가하세요
You just need to make sure your grounded and not wearing any synthetics. For example I put my bare foot on my radiator pipe as I know it's grounded
해당 답변은 도움이 되었습니까?
점수 0
댓글:
I hope you don't do this during the winter
의 답변
의견 추가하세요
aw ****. I did the same thing. I handled one of my phones internal working a ton without ESD protection. Am I screwed? I normally use an iPhone and since I just rebuilt my samsung the touchscreen doesn't work very well. I now realize my mistake, and wot do it again in the future,but I wonder if it's too late and I'm screwed, or if I could take it to samsung and have diagnostic tests done to see whether or not I really am screwed. Thanks a lot whoever's out there.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Basically you're playing a game of Russian Roulette here. It could kill you, wound you or not hit you at all.
Clearly dead is dead. But, wounded is hard to tell as it may take awhile before you bleed out. The same holds true with your phone ;-}
So the next time you should take the time to use ESD that way you won't even die!
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
gpprerunner 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 20
전체 시간: 4,324
