what's inside or pizza any1
i’m starting from scratch. I need to add a drive now. how do I “get in”?
좋은 질문 입니까?
좋은 질문 입니까?
Here’s the guide to add a drive (2nd) Installing iMac Intel 20" EMC 2133 and 2210 Dual Hard Drive I personally don’t recommend it! The Optical drives I/O is a very slow PATA connection ATA/100 (800 Mb/s). If you are thinking of adding a SSD you’ll be wasting it as the interface limits it.
The better direction is to replace the HDD iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement with a better drive. We still have an issue with this systems SATA port as its only SATA II (3.0 Gb/s) most SSD’s today are SATA III (6.0 Gb/s) and won’t work well in your system. You’ll need to find an older fixed speed SATA II (3.0 Gb/s) drive or a auto sense drive which will match the systems I/O speed. Review the drives spec sheet to make sure it lists SATA II if it doesn’t then its not able to support the slower interface.
안내서
난이도:
운영
1 hour
안내서
난이도:
운영
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 42
댓글 1개
I should have waited. I'm inside it now but lost video.
James Walker 의
