Is there a way to test charge port flex
Is there any way to test the charge port flex ? When plug in the test meter shows .47 and stays there . How can I determine if the charge port flex is bad
좋은 질문 입니까?
좋은 질문 입니까?
Connect it to computer, does it register? There are Tristar/port testers you can plug in but first is it in DFU Mode? Will it go into DFU Mode/recovery mode if not and connect. If it is or can connect, will it restore or update without error? You can open it and test with multimeter as well…
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 106
댓글 2개
When you plug the cord in it sounds and shows charging then it goes away
Phil Pusateri 의
Thanks it did not respond when I plugged it into the computer so the charge port flex will need to be changed—Thxs
Phil Pusateri 의
