주요 콘텐츠로 건너뛰기
Repair information for the Samsung 55" Smart TV with model number UA55JS8000 or UA55JS8000W.
6 질문 전체 보기
Screen issues, pictures and description attached.
When I power on my Samsung LED i get these screen issues the bars stay in same location but can have some flicker in them.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@helpwithsamsung could be a bad main board (most likely) or a bad T-con board. Worst case scenario it s bad LCD driver board (unlikely). I would start by replacing the main board. Get it from a place that has a decent return policy (or a cheap used one) so you can return it if it does not resolve your issue. OF course, check all the ribbon cables and make sure they are properly seated etc. Specifically the ones on the T-con and main board. Always check for obviously damaged components as well. You can always post some pictures of what you find with your QUESTION. That way we can see what you see.Adding images to an existing question
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Deni Carter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 280
