주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2366 질문 전체 보기
Why is my phone saying its disabled for 21 million minutes?
I broke my iPhone 4 screen a while back, so I repaired it with a new screen and I tried to go on it and its said iPhone disabled please try again in 21,958,460 minutes. Why?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 44
댓글 4개
just restore
I was having a problem with the screen and I tried to connected properly... and when I tried to reboot I received the message that the phone was disabled for 5 minutes... I tried after that but now is not turning on at all... Can you help me???
I wish someone would disable my work phone for 21,000,000 minutes
my phone is doing the same AND I'VE SWORN MORE THAN THAT...
댓글 달기
답변 11개
선택된 답변
The most reason is date and time settings. It happens to me a lot since i remove the battery from iphone 4 while doing repairs.
When you remove battery date goes back to 1960's or 1980's. and time becomes 6:00pm. That doesnt match the information on your iphone and it becomes disabled.
Because of that phone disable itself for more than million minutes.
The best way is to put a working sim card in it and reboot 2 times. While your sim register to network it sets your date and time automaticly to today. And you can use your phone without erasing it.
It worked for me more than 100 times.
해당 답변은 도움이 되었습니까?
점수 56
댓글 31개:
I have tried this method. I have an iphone 5s with this problem. The LCD was changed without a sim card in it. I have put a working sim card into the phone and rebooted more than 10 times. Have you got another solution for this?
great bang on thanks
It's TRUE, just try to put on a sim card reboot your phone, this solution can also help when your phone can't registry onto a network, in that case go to "date and time" set automatically and connect to wifi
Thanks a lot. It works!!!!!!
what if you have a wifi ipad?
댓글 26개 더보기
댓글 달기
Here is a similar question with a few good answers. Check it out and see if it helps!
해당 답변은 도움이 되었습니까?
점수 8
댓글 달기
I can fully accept that the phone is disabled because the time and date are wrong, I had this following a repair on a 5s and then it found a signal with the appropriate SIM card and was back in action. I now have the same issue with an iPhone 4 that I'm repairing and testing.
Regards,
Steve...
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
me as well, gotta love that Verizon decided the Iphone 4 they were releasing didn't need a sim slot
댓글 달기
Its several reasons why an iphone would be disabled, (1) the most common reason is to many failed attempts on the pass code screen. (2) If someone accesses your I-Cloud account from another device & change your security settings. (3) If your phone is connected to a computer with out-dated software ( I-tunes) this could disable your phone as well. You have two options re-connect your phone to i-tunes that you usually back up your phone on & press restore, or wait the allotted time & enter in the correct pass code on your mobile device.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Wait 21 million minutes? I don't think so
댓글 달기
I figured it out.
resintall the iOS and it solved the issue. to install the ios start the ipad in restore mode by following the below steps.
Disconnect the USB cable from the device, but leave the other end of the cable connected to your computer's USB port.
Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the device to shut down.
While pressing and holding the Home button, reconnect the USB cable to the device. The device should turn on.
Continue holding the Home button until you see the Connect to iTunes screen.
iTunes will alert you that it has detected a device in recovery mode. Click OK, and then restore the device.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
thank you man
i tested sim/reboot solution and my problem solved
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
i just had the same problem and found a solution :
just put a sim card on your iphone and call it with another phone.
if iphone receives the call, waiting time will be gone
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Just and Just try with working sim card and hard rest it twice. 100% 100% would work.
My husband iPhone 6s plus just got block for 2000 minute what should he do??
댓글 달기
I contacted “Apple Support” in regards to the above matter. I have an iPhone 4 that hasn’t been used in a long time but worked until one day when it asked me for the PUK code. At that time, I had no idea what the code was and didn’t lock my SIM. So, I tried common numbers me and my family would use (I gave the phone to my dad and thoght he may have unknowingly locked it.). He uses the same number for amost everything. Hence, I entered the number but it was not correct. So, I put in other numbers used by me and my family. I guessed wrong too many times and got locked out for 25 million minutes.
Years have gone by and a friend was in need of a phone. So, I decided to try to fix this problem.
I did all of the above along with trying do a factory reset. Nothing has worked.
So, I called “Apple Support”, I told the “Support Technician” the problem and then asked about the PUK code. She didn’t know what a PUK code was!!! She advised me to connect to iTunes through any computer and reset the phone to factory settings. I had no luck.
The laptop I connected the phone to via iTunes is long gone. I told support that I would Google “PUK code” and see if I coukd find a soloution. After googling it, I discovered that there is a default PUK code for my phone carrrier, AT&T.
Wish, I did this years ago prior to just guessing numbers.
I remember restoring the phone to factory settings and shutting it off. A few months later, I lost my iPhone 6 and wanted to use my 4 until I got a replacement through insurance. Upon turning it on, it said PUK locked enter code to unlock. This is when I got locked out for entering the wrong code too many times. I shut the phone off. It sat in a draw for years, until last week. didn’t turn it until last week.
I have tried removing the SIM, rebooting it, etc. I can’t figure it out.
If I activated the SIM under my At&t account would it fix the problem?
Any advice would be greatly appreciated.
Or do I have to wait 24 million minutes to enter the default code?
The phone was reset to factory settings years ago..
If I try to use iTunes it request the Apple ID and password which isn’t associated with that phone.
Could I access and resolve the lock out time by using any computer to sign into my old iTunes account that I used with that phone?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i took my iphone 5c to be repaired now its saying iphone is disabled try in 47 years i need help to fix this problem. i guess the repairer removed the battery resetting the date
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
this video can help you fix your disable iphone https://youtu.be/Ri25mE6wEoM
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Im having this issue with a 3gs, i have put a working sim card that is even celluar data enabled anf hard rebooted 3 times im still getting disabled for 25,378,272 minutes error this happened wheni pulled out my old phone and saw it was disabled for some odd reason and nobody used it because it was in a closet the whole time.I cannot restore it because it does not have any backups and i have lots of pictures on it
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ceejai marsh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 56
30일 전: 167
전체 시간: 242,756
