Why won't AOL 10.3.7 load?
Unable to open certain applications, AOL and Hewlett Packard PSC software for example. Also in the the text names of many functions in the toolbar have been replaced by alphanumeric designations, ie: TL9, TL11, TL8. In the Menubar they are replaced by numbers preceded by N, FV, ME, LB. The functions are operable.
I have reloaded Snow Leopard from the disc and updated it. I have tried to reload the HP and AOL software from discs but all get is the following:
Install AOL for Mac OS X quit unexpectedly.
Click Reopen to open the application again. Click Report to see more detailed information and send a report to Apple.
hp-all-in-one installer quit unexpectedly.
좋은 질문 입니까?
댓글 4개
This question was migrated from http://meta.ifixit.com/Answers.
iRobot 의
Adding a screenshot of what's happening would greatly help this description. Edit your question, and use the Images drawer at the bottom of your page to upload a picture, and drag it into your text to add it. Also while editing your question, fill in what type of computer you're using in the Device field. Doing both of these things will help improve your chances of your question being answered.
Taylor Arnicar 의
Norton Setup has the best products. Norton antivirus provides high security and protects the device from viruses. You can get Norton antivirus from Norton Setup. If you are facing any problem in Norton, then use the Norton removal tool. For further query, please visit <a href="https://w-wnorotn.com/setup/"> Norton Setup</a>
paul thomas 의
If you are able to sign in and read your mail, however you're not receiving new mail, there are a few things you can try to fix the problems.
Check your filters
Sometimes a filter can cause emails to bypass your inbox and be sent to either the trash folder or a different folder. You may need to check any filters you've created to make sure your messages are correctly organized.
Learn about delivery delays
Messages are often delivered right way though very rarely there may be a delay in transit. This is usually due to problems on the mail server, heavy internet traffic, or routing problems.
Unfortunately, other than waiting, you won't be able to determine if the message is delayed or undeliverable. If possible, ask the sender to resend the message to see if you can get the message a second time.
I hope this helps!
Mark Wilson
Mark Wilson 의
