주요 콘텐츠로 건너뛰기
Apple Macintosh 개인용 컴퓨터 수리 안내서 및 분해 정보입니다.
42809 질문 전체 보기
Why won't AOL 10.3.7 load?
Unable to open certain applications, AOL and Hewlett Packard PSC software for example. Also in the the text names of many functions in the toolbar have been replaced by alphanumeric designations, ie: TL9, TL11, TL8. In the Menubar they are replaced by numbers preceded by N, FV, ME, LB. The functions are operable.
I have reloaded Snow Leopard from the disc and updated it. I have tried to reload the HP and AOL software from discs but all get is the following:
Install AOL for Mac OS X quit unexpectedly.
Click Reopen to open the application again. Click Report to see more detailed information and send a report to Apple.
hp-all-in-one installer quit unexpectedly.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 4개
This question was migrated from http://meta.ifixit.com/Answers.
Adding a screenshot of what's happening would greatly help this description. Edit your question, and use the Images drawer at the bottom of your page to upload a picture, and drag it into your text to add it. Also while editing your question, fill in what type of computer you're using in the Device field. Doing both of these things will help improve your chances of your question being answered.
Norton Setup has the best products. Norton antivirus provides high security and protects the device from viruses. You can get Norton antivirus from Norton Setup. If you are facing any problem in Norton, then use the Norton removal tool. For further query, please visit <a href="https://w-wnorotn.com/setup/"> Norton Setup</a>
If you are able to sign in and read your mail, however you're not receiving new mail, there are a few things you can try to fix the problems.
Check your filters
Sometimes a filter can cause emails to bypass your inbox and be sent to either the trash folder or a different folder. You may need to check any filters you've created to make sure your messages are correctly organized.
Learn about delivery delays
Messages are often delivered right way though very rarely there may be a delay in transit. This is usually due to problems on the mail server, heavy internet traffic, or routing problems.
Unfortunately, other than waiting, you won't be able to determine if the message is delayed or undeliverable. If possible, ask the sender to resend the message to see if you can get the message a second time.
I hope this helps!
Mark Wilson
댓글 달기
답변 3개
선택된 답변
You should be able to use SMTP to access your AOL mail via the OS X mail app.
Or you can go to https://mail.aol.com to access our mail.
https://help.aol.com/articles/how-do-i-u...
Also, for your other apps, you need to find very old versions that are supported by 10.6.8, as most software developers have dropped support for Snow Leopard in the past few years. In fact the iPhone cant even work with the iTunes that are on those machines.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
You're probably trying to load very old drivers that won't work with 10.6. Go to the websites of the manufacturers and get the latest drivers from them.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
There are many reasons if your AOL desktop gold won’t load. Here are some reasons behind AOL desktop gold browser won't open
  • Poor internet connection
  • defective web settings
  • May be you are using old version drivers
  • Incompatible system
  • Overloaded RAM
  • May be email server is not detected or not found
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Shadow0109 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 757
